Discussion Groups
Simulation CFD
dousti
How to specify thermal contact resistances
209 Views, 2 Replies
01-28-2014 06:08 PM
I have two objects made of different materials touching each other. I would like to set a certain thermal contact resistance (with the unit of m^2.K.W(^-1)) for the shared area between two objects. How can I do it in Simulation CFD?
Thanks.
Please use plain text.
dousti
Re: How to specify thermal contact resistances
01-28-2014 06:15 PM in reply to: dousti
Well, I found the answer and will leave it here in case someone is interested to know:
Link to the Solution
Product Support
Royce_adsk
01-29-2014 07:48 AM in reply to: dousti
That is correct!
You can also use surface solid materials and define a thickness using either conductivity or resistivity as the material definition. I typically prefer that approach.
Best regards,
Royce Abel
