CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
How to simply select part and assign the material for thousand parts.
2 REPLIES 2
383 Views, 2 Replies
I had a question to ask especially in term of assigning material for hundred parts, any method that can be use in the Simulation CFD to quick select and assign material for hundred parts with easy way? Or it just only have one way which is have to select one by one for the part and assign it for the material.?
2 REPLIES 2
OmkarJ
Have you tried pressing ctrl or shift key for selct multiple parts? Also, when you import the part into SiMCFD, it groups all of them under "Unassigned". You can always right click and assign all of them a material that you want for most of your parts (often it is the fluid domain). Then you can always pick and choose the select few that have a different material and apply. It is easier this way.
in reply to: OmkarJ
Great! Now i've got this, thanks a lot.
