Hello. I made calculation with automatic mesh sizing. How to save this mesh for further use?
For example, I did «Cycles to run» = 5 and run the calculation. As a result, I got 5 of calculations with different mesh. Let's say I like the mesh in the third analysis (Scenario – Mesh 3), the grid satisfies the necessary accuracy of calculation and isn't very small (there will be faster calculation). How to save the mesh of "Scenario – Mesh 3"? I want to carry out the analysis with other boundary conditions, but I don't want to do analysis with automatic mesh sizing again.
It is necessary to clone "Scenario – Mesh 3" and to change boundary conditions? Or it isn't right?
Solved by OmkarJ. Go to Solution.
Yes, you would clone the scenario. In new scenario your mesh remains the same and you can change the boundary conditions. If in case you want to try out a different geometry, you would clone the design study itself, and while importing the geometry thorough the CAD software, "update the design study" with the new geometry.
