CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
How to optimize RAM and specify which CPU to run simulations on
2 REPLIES 2
1181 Views, 2 Replies
My computer has two quad cores.  Our S-CFD "Simulation CFD" (CFDesign) license only supports 1 CPU.  Each quad core has 6-RAM slots available to each independent quad core.
I want to maximize my RAM, but I only need to populate the RAM on that one CPU.
Is there a way to specify which CPU "S-CFD" (CFDesign) is to use during simulation to make sure it only uses that one CPU during the bulk of the analysis?
Tags (3)
2 REPLIES 2
marco.mueller
I'm not sure if I get exactly what you want, but the following topic describes how to address a certain number of cores (at the end of the first post):
http://forums.autodesk.com/t5/Autodesk-Simulation-CFD/Setting-up-Fast-Track/td-p/3211994
Is that sufficient? Why do you want to use only one CPU? For your machine it would be possible to use all cores.
Marco Müller
Product Support Specialist
Digital Simulation
Autodesk, Inc.
Royce_adsk
To answer your question, I do not believe there is a way to specify which CPU is used during solve.
Also, I believe you are mistaken about your license limitation, you should be able to use all 8 cores on that computer with Simulation CFD 2012.
-Royce
Royce.Abel
Technical Support Manager
