Discussion Groups
Simulation CFD
Active Member
n.jacky
How to optimise Autodesk CFD simulation 2012
580 Views, 3 Replies
02-28-2012 02:12 AM
Hello everybody,
I have a question regarding the optimisation of the efficiency of the software. Are there some modifications in my computert to allow CFD simulation to use the maximum of my machine.
Thank a lot
Please use plain text.
Product Support
apolo.vanderberg
Re: How to optimise Autodesk CFD simulation 2012
03-23-2012 05:56 AM in reply to: n.jacky
By default Simulation CFD 2012 will use as many physical* cores as exist on the machine
*Note we do not leverage Hyper-Threading (or virtual cores). If you have Hyper-Threading turned on, (assuming 4core cpu) we would at most use 50% according to Windows. Windows will report 8threads, 4 physical cores and 4 virtual. We will set 1 solver per real core.
Aside from that, there shouldn't be any other tweaks required to optimize your machine for CFD.
Apolo
New Member
ericdixon07
05-03-2012 08:25 AM in reply to: n.jacky
Does this mean that if I have hyperthreading enabled on my computer that the software will automatically adjust for this, or that I should disable hyperthreading to achieve better performance?
Product Support
apolo.vanderberg
05-04-2012 09:39 AM in reply to: ericdixon07
Correct. When we installed we assessed your system to find how many physical cores exist (excluding HyperThreaded cores) and we run enough solvers to max out those physical cores.
No further adjustments needed
