Hi
I happened to have read somewhere on the forums that there are hot keys to help with few operations in SimCFD. One of these is holding ctrl+shift and dragging the plane (instead of dragging the plane using the thin handles). It doesn't seem to work though.
Are there any such hot keys?
Omkar
Solved by Jon.Wilde. Go to Solution.
Hi Omkar,
You might need to have the Navigation Mode set to 'CFdesign' within Options -> User Interface but this method of moving planes should work.
Thanks Jon. But alas, I have set my navigation style to Pro/E, since it suits me best when I am switching between different 3D applications. I wish if it were a standard feature for all navigation styles though! Will post it to Idea Station.
