CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Help with running an Axial fan simulation
1 REPLY 1
robbyryder
497 Views, 1 Reply
I have a simple model of the ceiling fan I am trying to model but I am terrible at CFD and dont know what I am doing. I am going to attatch the model of the fan if anyone wants to try. Id prefer getting pointed to a tutorial but still. Im lost. Ideally id test the fan at 100, 150, and 200 rpm. When I run it it seems to view the inlets and outlets as walls and thus creates a net zero airflow. How do I make it so air freely comes in and out?
1 REPLY 1
Jon.Wilde
in reply to: robbyryder
Hi Robby,
Youe best bet is through using a rotating region, check out the guidelines here. If you are happy to run it withina tube, I would have 5x dia upstream and 10x downstream as a starting point.
Also make some simplifications to this model, close up the gaps and avoid regions where curves meet walls like this, creating a tough to mesh infinitely small angle.
Kind regards,
Jon
