CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Helical Screw Pump
10 REPLIES 10
Message 1 of 11
orchidhoanglan
831 Views, 10 Replies
Helical Screw Pump
I've been trying to produce a simulation of a non-horizontal helical screw pump, I am under the impression that, even with the HOF function, CFD will not be able to produce an acurate model since it can't model fluid surfaces but I would still like to see it through.
Unfortunately I can't seem to get it to solve. Initially there were some meshing errors related to the thickness of the blades in relation ot the overall scale of the model which I believe I've addressed but I still can't get this to work.
To simplyify it, I modelled it as screw in a straight tube with feeds in-line with the axis of rotation (in practice it would be fed from the side) It is a 4 bladed screw 1m long and 300mm across with a pitch designed for 45 deg. All this wrapped in a tube.
I've would attach the .cfz but it's apparently too large if anyone can help it would be much apprecated.
Thanks in advance!
10 REPLIES 10
Message 2 of 11
Jon.Wilde
in reply to: orchidhoanglan
Happy to open a Dropbox folder to look into this if you are happy to do so. I will send over a link.
I see that you are not on support with us but I will take a look and see if I can provide a few pointers.
Message 3 of 11
DOCKER
in reply to: Jon.Wilde
Any suggestion regarding run CFD for a spur gear pump. I have created 3D models fro fluid volume (including solid gear space) and gears? I need instruction about run setup
Message 4 of 11
Jon.Wilde
in reply to: DOCKER
I suggest you apply motion to each part (not a rotating region since they cannot overlap)
Boundary Conditions at inlet and outlet.
Fine, uniform mesh on moving parts and the fluid they move within.
Small timestep - obviously a transient run
Have you looked in our Wiki at all? I think there is a pump setup there which may help, minus the rotating region
Message 5 of 11
DOCKER
I am still have problem to run the gear pump CFD per your instruction. I tried to create a web support case. However, I am still waiting for subscription contract number from IT. By any chance you can find the number for me so I can create the support case and load the support file?
Jeffrey
Message 6 of 11
Jon.Wilde
in reply to: DOCKER
Hi Jeffrey,
What issues are you running in to now?
I can take a look to find a number sure. What is your product serial number? You should be able to find this under 'About'.
Kind regards,
Jon
Message 7 of 11
DOCKER
Could you send me a private email address so I can you the SN?
Message 8 of 11
DOCKER
It says
the analysis has been stopped because the Solver has exited unexpectedly.
Message 9 of 11
Jon.Wilde
in reply to: DOCKER
Hi Docker,
Please could you PM me?
If you look in the summay file it might give you some suggestions. I would try running this without free surface initially, start simple and then work up!
Kind regards,
Jon
Message 10 of 11
DOCKER
Jon,
I haven't talk to you for at least two years! Good to see you here. I don't know how to do teh PM on this forum. Could you send me your work email to jxdong@triumphgroup.com?
TThanks,
Jeffrey
Message 11 of 11
Jon.Wilde
in reply to: DOCKER
Hi Jeffrey,
You simply need to click my name and then 'send private message'. I will email you anyway though.
Did we work together before?
Best regards,
Jon
