CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Having trouble launching CAD model into Simulation CFD from Inventor
2 REPLIES 2
ckasunic
900 Views, 2 Replies
When opening a CAD model into Inventor, the option to launch into Simulation CFD is not given, while the option to launch into Simulation Mechanical is. Any ideas how to fix this, or how to launch my CAD model into CFD a different way?
Tags (1)
2 REPLIES 2
ilyas_drawbridge
in reply to: ckasunic
Inside Inventor, check whether the simulation CFD add-in is loaded or not (Tools>Options>Add-In). If you are using the new CFD 2014, then you can directly open inventor .iam and .ipt files from within CFD.
Regards
Ilyas
Royce_adsk
Run this program to try to fix your CAD Connections:
C:\Program Files\Autodesk\Simulation CFD 2014\SimCFDConfig.exe
You may need to select 'run at administrator' when running this setup program.
-Royce
Royce.Abel
Technical Support Manager
