Discussion Groups
Simulation CFD
Valued Contributor
marco.mueller
Get element count for mesh adaption
257 Views, 3 Replies
05-23-2012 12:32 AM
is there a quick possibility to see the mesh element count for all scenarios created via mesh adaption, except from activating them manually and checking the status? Seems that there are no *.st-files saved any longer?
Marco
Please use plain text.
Product Support
Royce_adsk
Re: Get element count for mesh adaption
05-29-2012 12:14 PM in reply to: marco.mueller
Hi Marco,
Do you see all the mesh counts in the output window?  I believe they are all there if you scroll up.
The solver text files are missing and I will make sure that a defect gets logged.
-Royce
Royce Abel
Valued Contributor
marco.mueller
06-06-2012 02:36 AM in reply to: Royce_adsk
Hey Royce,
thanks for that! Of course they are visible, but only if the design study is opened.
Marco
Product Support
Royce_adsk
06-06-2012 02:32 PM in reply to: marco.mueller
Yeah, otherwise you will need to go into each status file and extract the data manually.
When running adaptation the UI should be left open anyways.
Royce Abel
