is there a quick possibility to see the mesh element count for all scenarios created via mesh adaption, except from activating them manually and checking the status? Seems that there are no *.st-files saved any longer?
Marco
Dipl.-Ing. (FH) Marco Müller
Application Engineer Digital Simulation
Mensch und Maschine Deutschland GmbH
www.mum.de/cfd
Solved by Royce_adsk. Go to Solution.
Hi Marco,
Do you see all the mesh counts in the output window? I believe they are all there if you scroll up.
The solver text files are missing and I will make sure that a defect gets logged.
-Royce
Hey Royce,
thanks for that! Of course they are visible, but only if the design study is opened.
Marco
www.mum.de/cfd
Yeah, otherwise you will need to go into each status file and extract the data manually.
When running adaptation the UI should be left open anyways.
