CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Force as boundary condition
2 REPLIES 2
350 Views, 2 Replies
Now I have a question for the dynamic simulation. Is this to det a spring force in the dynamic simulation that works against hydraulic pressure? In the edge terms it does not seem to be possible, there is only "pressure" as definition there.
I'm grateful for every help.
2 REPLIES 2
Jon.Wilde
If I understand you correctly you should have an internal part (a poppet of valve) that is moving? To this you could assign a Motion condition, using the Motion thumbnail at the top. Here you could set it to move linearly and also assign a spring force to it. This would act behind the valve and we would see motion of it as the hydrostatic forces act also.
I suggest you refer to the help once you are in the spring setup, it gives some useful advice on the direction (this sign) that the forces must be given.
Kind regards,
Jon
in reply to: Jon.Wilde
Great thanks to your reply. I've searched in wrong options but now i found it.  The "Force" property to choose is to be done directly on the valve in motion-conditions.
Very nice!
cheers
