CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Fluid Flow over an object
11 REPLIES 11
Message 1 of 12
sfitzgerald2
1097 Views, 11 Replies
So as the title of my message states, I'm trying to look at the flow of fluid (specifically water) over an object in Autodesk CFD. I've gone through tutorials and looked at other people's examples, but for some reason I still can't get it to work. I've made a virtual flow tank and have placed my object inside of it. I set the material for the object (say abs molded) then set the material for the flow tank (sea water liquid phase). I've placed the flow rate and so forth but for some reason I'm getting an error message stating that "The density of the working fluid is less than or equal to 0". I've gone back and chekd all the data, I've checked the environment data as well and it all seems squared away. Does anyone know what I'm doing wrong?
-Cheers
11 REPLIES 11
Message 2 of 12
harm
in reply to: sfitzgerald2
Hello there, I have exact the same problem, is somthing wrong with setup?
Message 3 of 12
Royce_adsk
Hi Sam,
What you are running into is actually a known issue.
What I would suggest as a workaround is to create a new material with the same material properties as our Sea Water (Liquid phase), but change the 'Phase' property to 'Variation Method: Vapor Pressure' with a value of 0 instead of the linked Vapor Material.
Does that allow your model to work successfully?
Royce
Royce.Abel
Technical Support Manager
Message 4 of 12
harm
in reply to: Royce_adsk
Hello, I tried this but it did not solve the problem
Message 5 of 12
I'm having the same problem. Any idea why this is happening, Royce?
Aaron
Message 6 of 12
Jon.Wilde
Have either of you tried launching from CAD and setting it up again? We have seen this work also.
Message 7 of 12
No I have no tried that yet. I'll go and see if that works tomorrow. Do you know if there are any good video tutorials? I'm trying to simulate flow over hydrofoils and as I've said before, I'm running into some problems.
Message 8 of 12
Jon.Wilde
If you have been through the tutorials I would have thought you have most of the knowledge you will need for this.
I suggest you consider running in 2D in possible. The more mesh we have with external aero models the better, and utilising the 2D approach can be of great benefit, more mesh, lower runtime.
It would also be worth using Advection Scheme 5 and mesh adaption too.
Other than the density issue, are you finding other problems?
Message 9 of 12
Was this issue ever solved? I'm having the same problem.  I was able to run all the tutorials, but when I try my own problem (sea water buoyant flow and convection), I get "The density of the working fluid is less than or equal to 0".
Message 10 of 12
Jon.Wilde
Did you try launching from CAD and setting the model up again? This was the only workaround I found to work reliably.
What version of CFD are you running?
Kind regards,
Jon
Message 11 of 12
travward
in reply to: Jon.Wilde
Jon, What do you mean by launching from CAD? You mean from inventor? I'm running 2013 and getting this issue. I was told it was an universal issue and that the only fix was to upgrade..
Message 12 of 12
Jon.Wilde
in reply to: travward
Yes, I mean to start from Inventor and launch again into CFD. Perhaps an upgrade is the only solution but I have also seen the problem simply disappear when starting again from scratch like this.
