I have a pretty complex housing, and would like to determine it's internal air volume. Since CFD creates the air part, I was wondering if there is a way to extract the volume of the created part? I know you can see the overall simulation volume in the status file after meshing, but my model is crashing the solver during meshing. I'm telling it to solve 0 runs, but it gives this error: "The Analysis has stopped because the Solver has exited unexpectedly". I have tried closing the rest of the programs on my computer, but the solver still crashes. Any suggestions?
Yo ucould use the 'Part' option in results to calculate this? Select the volume and press 'Calculate'. It does need to be meshed though.
Sounds like something in your setup is causing an issue, please share your CFZ file.
Are you running on a local drive? You do need to be, this can also cause the error you are seeing.
Thanks!
Jon
Thank you Jon,
Yes, I am running on a local drive. Could I send you the share file directly? I have been asked not to post our geometry to a public forum.
-Abbey
Sure can. It looks like you have a suscription contract with us, so could you log a case on the subscription center and we can work on it from there?
Thanks!
Jon
