There is a constant error that keeps on appearing while using the Faucet Example Model. The error message "Display driver NVIDIA Windows Kernel Mode Driver, Version 267.96 stopped responding and has successfully recovered" crashes Simulation CFD 2013 constantly. It cccurs when I try to use the Geometry Tools to seal the ends of the faucet while using the Inventor Fusion model. Please help.
The graphics card I am currently using is the Nvidia Quadro 1000M.
Solved by Jon.Wilde. Go to Solution.
Have you tried updating your graphics drivers? How about setting the 3D settings to CATIA, which often helps with running CFD.
Hi Jon,
Thanks for the help, Updating the driver AND changing the 3D settings to CATIA helped solve the problem.
Thanks for letting me know, glad it is all working now.
