Discussion Groups
Simulation CFD
Active Contributor
kaiwei
External Aerodynamics Car : Region Refinement
241 Views, 2 Replies
12-21-2012 01:09 AM
How do you get the read the tutorial for meshing regions for the car? The tutorial wants to set the following
+X = 2.25 -X = 0 +Y= 2.5 -Y = 0 +Z = 18.0 -Z = 10
However, I am unable to set these numbers for the meshing region. What I have done is in the attached files. Please help.
Please use plain text.
Product Support
wildej
Re: External Aerodynamics Car : Region Refinement
12-21-2012 04:24 AM in reply to: kaiwei
Hi Kaiwei,
Your best bet is simply to use the pull arrows to resize the region roughly where you expect there to be turbulence, it might be simpler and more intuitive than copying over the numbers?
Jon Wilde
Distinguished Contributor
ilyas
12-21-2012 08:07 AM in reply to: kaiwei
Try,
X Offset= (X1+X2)/2
X Length=|X1-X2|
Where X1 and X2 are the X limit of the region walls. It should apply the same for Y and Z.
Regards
Ilyas
