Dear Autodesk Sim CFDers,
Can the CFD results be exported to Paraview VTK format? There is some features in paraview that I need for a project.
Thanks!
Pei-Ying
Hi, Heath,
Quite often, I need to display the velocity vectors in 3D domain (not on a plane). I tried to do this in Autodesk Sim CFD, but, never find out how to do it.
I will try the Tecplot approach to see if I can get the results into Paraview.
Thanks!
Pei-Ying
Another area I see where paraview is relevant is in creating custom variables. Often I when I have to visualise or calculate bulk values certain non-standard variables (like flow inclination angle, dynamic pressure etc), I use Paraview. Care must be taken here though, since Paraview is dimensionless viewer and hence appropriate conversion factors should be applied to default units in which Tecplot file was exported, to preserve the fidelity of the physics.
Heath,
In the past I have mostly used ANSYS products (FLUENT/CFX) and I like the in-built CFD-post visualization package provided with these products, which allows custom variables and expressions. But coming from there, I find Paraview a bit clumsy and the fact that it is unit-less makes things a bit tricky, unlike what I experienced with CFD post where expressions can be created using in-built or user-defined variables, without worrying about the units. But then, Paraview is a free package and it caters to my needs when I need to deal with non-standard variables, so I don't mind if it's a bit unergonomic
Any capability to create custom variables and expressions, not only during post processing/visualisation but also during pre-processing, thereby allowing more versatility in creating monitors for desired quantities, is a big plus for me.
Regards
