CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Export function (.unv // TecPlot - File)
5 REPLIES 5
1114 Views, 5 Replies
Hello autodesk community,
i have a problem with the export from autodesk to other programms.
i cannot export a mesh file (.unv) or a solution file (Tecplot). All the time i get the same errormessage.
I have followed all instructions.
i have folder permission. Hdd space is enough, and i am the only user of this file.
Maybe you have other tricks.
thanks
5 REPLIES 5
Royce_adsk
You probably need to upgrade to 2013 SP1.
-Royce
Royce.Abel
Technical Support Manager
in reply to: Royce_adsk
thanks for the clue.
why i don*t can export a mesh with Mesh Enhancement??
Royce_adsk
I believe it was because the .unv doesn't support that element structure.
-Royce
Royce.Abel
I have downloaded a very recent version (1 week ago), and I am unable to export any the results to either the Tecplot, Fieldview, of Universal file, or CSV data (none of the data export seems to work). I see in the lower left hand corner message saying that it is exporting, the Scenarios Folder does not contain any exported information. Here is the version information:
Must admit that there is no sensible version number presented concisely there (is it 13.0.2013.02?) Build number (if date based, seems old).
Any suggestions?
-Kevin Colburn
kevin@ceisoftware.com
RAALVM
Hi I seem to have the same problem. I can't export to TecPlot File format. The CFD doesn't tell me anything that the results are not compatible with the TecPlot format. I have the latest version of the Autodesk Simulation 360. Is there a flag that can allow me to export the results to TecPlot?
