CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Export CFD Created Volume to solidWorks/ few other questions
1 REPLY 1
cpierce223
500 Views, 1 Reply
Is it possible to create a volume using the CFD tool and export that to solidworks for editing. Or can I edit within autodesk if I only have a simulation key, not the CAD software. In detail, the problem is i want to model a centrifigul pump and I want to eliminate the filets on the water without changing the tube shape. Also I want to use the valute casting to create the volume and than delete it in the CFD but when I click remove it stays, also I surpress it and it stays, just slashes the name bar. Any suggestions?
Chad
1 REPLY 1
Royce_adsk
in reply to: cpierce223
Hi Chad,
It is not possible to export geometry from Simulation CFD.
You might want to explore Inventor Fusion for geoemtry simplification.
-Royce
Royce.Abel
Technical Support Manager
