CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Exhibition Hall Model : Results Not Matching
1 REPLY 1
kaiwei
645 Views, 1 Reply
Is there a way to refresh the images in the Design Review Center? There is a mismatch between the results in the Output Bar and the results in the Viewport. The results for the summer temperature cut plane are different when you compare the View Port and Output Bar. I have already tried updating all the images and critical values. Thank you.
1 REPLY 1
samwicks
in reply to: kaiwei
At first glance, it appears the images are different because the legend is scaled differently.
In the viewport, the lower bound is the lowest temperature of both simulations, whereas the study bar lower bound is scaled to the lowest temperature of that result set only.
Try altering your legend options (right click on the colour bar, options, user specified range) and see if this solves your issue.
