There is an error while launching .rvt files from Revit 2013 into Autodesk Simulation CFD 2013. The error message is "Can't find PSI.DLL". Is there a reason for this error? And is there a way to solve it? Thank you.
Solved by Royce_adsk. Go to Solution.
Try this workflow! I have had a lot of success using this workflow to get around the psi.dll error message.
7) Launch
Hi Royce,
Thank you for your help. Your suggestion has worked and we realized that the issue was due a Revit template incompatibility.
