Discussion Groups
Simulation CFD
Valued Contributor
0 Kudos
Error: Cannot open the file
247 Views, 5 Replies
12-20-2012 12:45 PM
I am trying to open a cfdst file that I previously had no problems with.  I now get the following error message.
107 Kudos
Re: Error: Cannot open the file
12-21-2012 04:24 AM in reply to: jmcternan
Faced t he same problem and I realised that this happens when you are trying to open a cfdst file that is already open!
Try closing all the SmCFD windows and restart  the windows. Perhaps it may solve this.
Cheers
OJ
Valued Contributor
0 Kudos
12-21-2012 06:16 AM in reply to: OmkarJ
Thanks.  I didn't have any other instances open; maybe has something to do with the cloud.  I did stop the job and then cancel the instance on the cloud.  I had another job that ran fine and when I tried to open the file again after a few weeks I got this error.  I really need to be able to open these jobs.
Member
0 Kudos
03-07-2013 03:46 PM in reply to: jmcternan
Did you ever resolve this? I am all of a sudden getting the same error now on one of my projects.
Valued Contributor
0 Kudos
03-08-2013 05:20 AM in reply to: mark_youmans
Yes I think I have.  I think it happens when an instance is already open.  Occasionally all icons and any evidence of the running program will vanish, but it will be running in the background.  Maybe a problem with multiple monitors.  Check task manger to see if it is running an instance that you did not know about.
Spoiler
Member
0 Kudos
03-08-2013 11:51 AM in reply to: jmcternan
Unfortunately I don't think this is the case. I have rebooted my PC a few times and no luck. I've run other simulations just fine, solving them and opening and closing them with no issues. I even tried copying the one that doesn't open to a thumb drive, then opening on a differnet computer, and no luck. It seems something perhaps got corrupted in the file. I can open the support file just fine also.
