Discussion Groups
Simulation CFD
New Member
2 Kudos
Enhancement: Import Gerberdata to simulate a PCB with high current
261 Views, 2 Replies
10-16-2012 03:28 AM
it would be helpfull, if CFD could import and handle real Gerber-Data from ECAD-Designs to simulate the power dissipation of a PCB.
Many electronic drives (E-Bike, E-Car, ...) need a lot of current, which results in heating of a pcb due tue the copper resistance.
For a correct simulation of the heating and cooling of such a pcb it is necessary to import real Gerber-Data.
Alois
ASP
Employee
65 Kudos
Re: Enhancement: Import Gerberdata to simulate a PCB with high current
10-29-2012 07:24 AM in reply to: alois.spiess
Thanks Alois. Appreciate the feedback. If there is a sample file you can share as an example of the data you want to work with, can you send it to Simulation.CFD.Enhancements@autodesk.com?
Jon
New Member
2 Kudos
02-21-2014 01:07 AM in reply to: hartogj
Hello Jon,
is a sample file (Extended Gerber Data) necessary ?
Will Autodesk this feature implement in the next time ?
Alois
ASP
