CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
dynamic and flow simulation
1 REPLY 1
vsmokkapati
263 Views, 1 Reply
Hi all,
I am trying to simulate something which is like a double acting reciprocating cylinder. in this case if the pressurised fluid is admitted into the cylinder using inlet valve, the impact due to the pressure on the disc/piston inside the cylinder should be able to move inside the cylinder.
Is It possible with this software??
Thank you.
1 REPLY 1
You can use Sim CFD to analyse flow driven motion, which is your solid piston being moved by the working fluid, though it will require some extra input if you have friction and opposing forces.
Regards
Ilyas
