Discussion Groups
Simulation CFD
1 Kudo
Doesn't save the results
314 Views, 2 Replies
05-29-2012 03:47 AM
Hi I have a CFD 2013 student edition.If after I exited the program after a simulation, when I load the simulation again It doesn't load also the results of the simulation.
Is this because of the license ?
Vlad Martian
Employee
11 Kudos
Re: Doesn't save the results
05-29-2012 03:56 AM in reply to: romar_ro
Hi Vlad.. This should have nothing to do with the license.
Where is the original CAD geometry coming from and how are you launching it into SIMCFD? You might want to post a support file (File>Save>Share File) to the forum and maybe someone can test it on their end.
The commercial and EDU versions of SIMCFD are essentially exactly the same.
1 Kudo
05-29-2012 04:37 AM in reply to: derrek.cooper
Ok, thanks. Anyway I have discovered where I was wrong. Every time I opend the simulation I piked the wrong file (.CFZ instead of *.cfdst).
Thanks anyway.
