Discussion Groups
Simulation CFD
Member
0 Kudos
Do the Autodesk Simulation CFD 2013 is intended to work on shared network?
164 Views, 1 Replies
02-25-2013 03:16 PM
I installed the Autoesk CFD 2013 in the local w7 - 64 bit and copied the installed binares to the \\ shared network drive and try to execute the SIMCFD.exe from another w7 machine.
1.Error out for reg value HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Simulation CFD is fixed
2.Material databse file not found issue was fixed in C:\ProgramData\Autodesk
Still facing the error from the License perspective...
Question is Do the CFD 2013 is intented/designed to work from a shared drive?
Product Support
231 Kudos
Re: Do the Autodesk Simulation CFD 2013 is intended to work on shared network?
02-25-2013 07:00 PM in reply to: sureshdamotharan
It is not intended to be run from a network/shared drive.
-Royce
Royce Abel
