CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Do the Autodesk Simulation CFD 2013 is intended to work on shared network?
1 REPLY 1
331 Views, 1 Reply
I installed the Autoesk CFD 2013 in the local w7 - 64 bit and copied the installed binares to the \\ shared network drive and try to execute the SIMCFD.exe from another w7 machine.
1.Error out for reg value HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Simulation CFD is fixed
2.Material databse file not found issue was fixed in C:\ProgramData\Autodesk
Still facing the error from the License perspective...
Question is Do the CFD 2013 is intented/designed to work from a shared drive?
1 REPLY 1
Royce_adsk
It is not intended to be run from a network/shared drive.
-Royce
Royce.Abel
Technical Support Manager
