CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Distributed resistance problems
2 REPLIES 2
432 Views, 2 Replies
I am studying how to distribute a gas blow to a porous bed.
Gas velocity in bed is low, only 0.11 ft/sec.  I am using the constant model that has both viscous and inertial terms.
No matter whatI set the constants to, I cannot net more than a few thousandths of an inch of water pressure drop through the bed.  Pressure drop is in fact 0.84 inches of which 3/4 is from permeabliity and the remainder inertial.
If I use a resistance surface rather than a volume I can get the drop I want.  Unfortunately this does not show how the bed should be evening out the flow.
What am I missing here?
2 REPLIES 2
waited
I would recommend using the flag no_difu_tensors 1.  With the solver flag set to one, you will revert to another distributed resistance model that does a better job for porous region for low speed flows.
Dave
in reply to: waited
Thank you Dave.
That worked.
