I am studying how to distribute a gas blow to a porous bed.
Gas velocity in bed is low, only 0.11 ft/sec. I am using the constant model that has both viscous and inertial terms.
No matter whatI set the constants to, I cannot net more than a few thousandths of an inch of water pressure drop through the bed. Pressure drop is in fact 0.84 inches of which 3/4 is from permeabliity and the remainder inertial.
If I use a resistance surface rather than a volume I can get the drop I want. Unfortunately this does not show how the bed should be evening out the flow.
What am I missing here?
Solved by waited. Go to Solution.
I would recommend using the flag no_difu_tensors 1. With the solver flag set to one, you will revert to another distributed resistance model that does a better job for porous region for low speed flows.
Dave
