Discussion Groups
Simulation CFD
Valued Contributor
6 Kudos
disply velocity vector inside the flow domain?
96 Views, 3 Replies
09-06-2013 06:20 AM
Dear CFD experts,
Is there a way to display global vector inside the flow domain, instead of just on the surfaces?
I would like to display the velocity vector inside the "whole" flow domain.  I found that global vector only display on the fluid surfaces and using the plane is somehow limiting and not seeing the whole picture.  Any suggestion?
Is there a way to export the results to either tecplot or paraview?
Thanks!
Pei-Ying
Product Support
147 Kudos
Re: disply velocity vector inside the flow domain?
09-08-2013 08:36 AM in reply to: pei-ying.hsieh
Aside from using cut-planes the other option would be to use an ISO surface. Switch it from Shaded to Outline and show vectors on it. You can change the velocity value you are viewing, which may also help to visualise the flow.
Jon Wilde
Valued Contributor
6 Kudos
09-09-2013 06:16 AM in reply to: pei-ying.hsieh
Thanks for the reply!
But, If I use iso surface, then, the vector is still only displayed on the iso surfaces, correct?  So, it is not really what I am looking for.
Maybe I should submit a feature request for this.
Best Regards,
Pei-Ying
Product Support
147 Kudos
09-09-2013 06:35 AM in reply to: pei-ying.hsieh
Yes, this is correct, although you can also use multiple ISO surfaces.
I have thought about this myself before and find ISO surfaces an perfectly convey what is occurring - I am not clear if the observer might be overwhelmed with details if we show the vectors everywhere at once?
Feel free to log a request but if you could show some examples also that would be really useful.
Kind regards,
Jon
Jon Wilde
