I have a simulation that has crashed and the design study environment will not open. What I did:
NOTE: This particular design study had about 2 designs, and about 12-15 scenarios between both designs. Since I was unable to create a cfz of the design study, I have zipped up the entire directory and uploaded it to Google drive. The link is here. https://drive.google.com/file/d/0B-Ea9c9_8p14aC1JbXVDOF9KYjA/edit?usp=sharing (Note: It is 7.5 GB).
Solved by OmkarJ. Go to Solution.
You may have a cfz file created in the folder you have your simulation automatically. One workaround is to open this, solve for 0 iteration to create a mesh, copy all the files from Solver folder of crashed simulation to the Solver forlder of this simulation and run from the last iteration to map the results on the mesh. This way you can recover all the scenarios for which the results were saved.
Sometimes, it may also work to delete the folder of the name of the scenario that you suspect caused the problem (supposedly the last one?. Deleting that and opening the cfdst file may help, but not guaranteed. Make sure you have a backup before you risk this.
