CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Density and viscosity variation in summary file.
3 REPLIES 3
napoleonm
347 Views, 3 Replies
CFD 2013
We have notice that in some simulations after running an internal flow simulation using CONSTANTS density and viscosity values for an incompressible analysis setting, the summary files shows  important variations in these properties, what is happening in the simulation?.
Perhaps for another similar simulation with the same settings, summary file shows same value at minim, maximum and mean values as it should be.
3 REPLIES 3
OmkarJ
in reply to: napoleonm
Just exploring this point further, some authors propose that an incompressible flow has a constant density along a particle pathlines, but different pathlines may have diferent densities and thus there may be different densities at different regions in space, but in time the density is constant. And there is an ideal case of incompressible flow where the density on all pathlines is also same, and thus, is same across the space and time, and then it is turmed as "homochoric" or "nondilatational." I don't know if this has to do anything with this observation though...
Royce_adsk
Not something I've noticed. Do you have a simple model to share where you see this?
Best regards,
Royce.Abel
Technical Support Manager
napoleonm
in reply to: Royce_adsk
I can share the summary file in the forum, but I will sent the support file using a support call.
