CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Defrosting simulation
2 REPLIES 2
283 Views, 2 Replies
Hi all,
I'm doing a defrosting simulation,
Boundary conditions -14ºC ext and 20ºC int. The glass is heated by 4 heaters.
First I do the flow simulation and once converged I do the transient analysis, do you think this is the correct approach t this problem.
See attached pictures of parameters used.
2 REPLIES 2
Jon.Wilde
If you are not looking at a natural convection analysis (which would include air_variable and gravity) then yes, you can run flow first and thermal second.
Check that your external surfaces are sensible - should they be a fixed temperature or maybe a film coefficient? The latter might be better unless the walls are 100% fixed at a temp.
Don't use an unknown condition (this is more for compressible analyses). Refer to the guide here for a nice natural convection setup - or use forced convection.
Jon
in reply to: Jon.Wilde
Thanks, the external -14ºC is fixed but interior 20ºC could be a film coefficient.
Regarding the transient analysis, I've tried but it seems no to work well, I set time step 1 second and I want to store each 60 seconds til it reaches 20minutes, It only shows me after calulation the first 6 or 7 seconds.
