Discussion Groups
Simulation CFD
csjhun
Default View setup
131 Views, 2 Replies
11-06-2013 05:50 AM
Is there a way to setup the View as Orthographic as a default view without going back to the view cube and switching to orthographic?
Please use plain text.
Product Support
wildej
Re: Default View setup
11-07-2013 01:13 AM in reply to: csjhun
I am not aware of any way to do this, no. Typically the model launches with the same view as the CAD system.
Kind regards,
Jon
Jon Wilde
Product Support
Royce_adsk
11-08-2013 06:49 AM in reply to: wildej
You will need to modify your options if you want perspective projective enabled or not.  Then close down and reopen Simulation CFD.
That should do it for you!
Royce Abel
