CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Default units for bulk Results
4 REPLIES 4
jiri.jirat
485 Views, 4 Replies
Hello All,
Is there any chance to set default units for Bulk Results in CFD 2015?
When you switch between Designs and Scenarios, CFD always change units for example to mm/s for velocity.
(I want m/s for velocity)
Any Idea?
Jiri
4 REPLIES 4
tong6
in reply to: jiri.jirat
Currently we don't provide bulk UI unit consistence between sessions. The units in bulk dialog will always be defaulted to your design length units when you open the study file. So I guess your design length unit is mm. You can switch mm to m then you will get m/s in bulk result.
jiri.jirat
Thanks for answer
nice tip
-Jiri
Jon.Wilde
Just to add - you cannot change the units once you have solved a model - so open the _support.CFZ file that would have been created and change it there before you run 🙂
Jon
marco.mueller
in reply to: Jon.Wilde
http://forums.autodesk.com/t5/simulation-cfd-ideastation/true-default-units/idi-p/5425329
Dipl.-Ing. (FH) Marco Müller
Application Engineer Digital Simulation
Mensch und Maschine Deutschland GmbH
www.mum.de/cfd
