I am currently working on creating a model of a CVT (continuously variable transmission) system. This system has fins built into the clutch that is supposed to act as a centrifugal fan. The main concern of this project is getting the clutch to rotate at a given angular velocity to generate airflow. (Moving solid part? moving mesh?) This clutch is not a fan or centrifugal pump because it doesn't have a specific curve to follow. It is just a simple part rotating.
This would be possible through the use of a Rotating Region, please check out the guide here: Pump and Fan Guide
Kind regards,
Jon
