Discussion Groups
Simulation CFD
1 Kudo
cutplane script to save as table csv
115 Views, 1 Replies
05-01-2013 11:20 PM
I want to know if there is a posibility to save a cut plane as table using script automation. The class cutplane doesn't have any function that do this. And in the UI there is the possibility to save a cutplane date into an csv file. I want to automate this since I have to do some custom calculations for each plane and I have also more scenarios for which I want to apply
Product Support
232 Kudos
Re: cutplane script to save as table csv
05-06-2013 11:31 AM in reply to: romar_ro
This portion of the cut plane object in the API has not been implemented.
I would suggest that you make some enhancement request here so that the development team is aware of your need.
http://forums.autodesk.com/t5/Simulation-CFD-IdeaStation/idb-p/82
Royce Abel
