CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Custom Material in CFD not changing enviornment properties
1 REPLY 1
rockdesign101
284 Views, 1 Reply
I am new to CFD and have figured out the software mostly. I was using one of the hydraulic oil materials Inventor CFD has supplies stock. But for the project I am working on I need to use Therminol 66 as my fluid. I made my own material in the material editior to relfect the theriminol. But when I go to set the enviorment the properties listed are the same properties of the hydraulic fluid. Does anyone know how to chage this?
Any help appreciated.
1 REPLY 1
tong6
in reply to: rockdesign101
Can you tell me what mat environment setting UI you are using to change properties? If you go from the dsa bar, there is a mat environment settings dialog to set the scenario level property.
