Hello all,
When you use Planes and Bulk results, CFD shows you results for each area which plane splits. - this is OK
Decision center shows you only one - total value. This is BAD
Because when you have more outlets than one it will show you only one - cumulative value and you can't compare designs or scenarios.
Is there any way how to do this?
Thanks a lot
Jiri
2 Years and still no answer for this?? I am in agreement, I am running multiple scenarios where I would like to know the bulk flow rate in several different regions that a plane cuts through. It is the determining factor in the simulation I am running at the moment. Instead of using the decision center I have to individually open each of the results and measure the bulk. Seems counter-intuitive to what the decision center was designed to do. Hopefully this is something addressed in the near future.
Dipl.-Ing. (FH) Marco Müller
Application Engineer Digital Simulation
Mensch und Maschine Deutschland GmbH
www.mum.de/cfd
