I would like to know is there any possibility to get something like simulation result summary file. There is Summary file in ribbon, but what it gives is not exacly what im looking for.
For example is there a way to get results with snapshots, plots and so on, in user friendly file format, like .doc, .pdf, o html.
I am looking for something similar to Report file from Autodesk Inventor simulation module, there you get html file with snapshots, max forces and so on.
As far as I can see all documentation is only posible to create manualy from snapshots you make, plots, graphs and so on, is that right?
Yes this is right, there is no other reporting at present.
There is a powerpoint addin which allows embedding vtfx's which might be useful?
Jon
Thank you for the answer.
I get error when trying plug-in on Word and I press Insert button:
Run-time error '4218'
Type mismatch
On power point I get this error:
Run-time error '-2147467259 (80004005)':
Method 'AddOLEObject' of object 'Shapes' failed
How could I fix that? I am using MS Office 2010
This addin is for Powerpoint only, try that and it should work OK.
