CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
CFD to Mech
3 REPLIES 3
360 Views, 3 Replies
CFD to Mech
Dear CFD users,
Can I please request information on following plz,
1). The bottom link for CFD-To-Mech "Pressure Mapping" from Exchange Apps -will it be included with Release 2015 CFD ???
http://apps.exchange.autodesk.com/SCFD/en/Detail/Index?id=appstore.exchange.autodesk.com%3Asimcfdtos...
2). More work arounds example would be required to understand the app. and utilise it to determine its limitations.
Many Thanks,
Cheers,
Ajay.S
Tags (3)
3 REPLIES 3
apolo_vanderberg
Ajay,
This is something that the development teams have been looking in to.
For #2 I'm not sure I'm following the comment.
You can use the app to map pressures from CFD to any Brick/Tet meshed Linear Static Stress model in Mechanical.
There is a video on SimTV of how to use it (here)
Apolo
in reply to: apolo_vanderberg
Can this add-in be run in a configuration where the wind tunnel is modeled in CAD, and I simultate the whole assembly, instead of using an external volume in CFD?
In  that case, can I just suppress the wind tunnel in FEA?  or do I need the two CAD models to match exactly?  Does it matter if the wind tunnel and part interfere or will that confuse the add-in?
I ask because I have tried this a few times now and it always hangs  where it says "This operation could take some time please be patient" (or rather, the add-in seems to terminate without notice, since CFD still responds).
I have been patient but there are no processes running and the add-in never finishes running.
Thank you.
Also - do we need to avoid geometry modifications if CFD such as remove small surfaces?
