CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
CFD starting problem
2 REPLIES 2
472 Views, 2 Replies
Hello, I just installed simulation CFD(student Ver.) on window vista and I've already activated it. Because this is first time to use this program, I read a manual. According to manual, it has several tabs named setup, results, view, and get started in default page, but in my case I can't see any tab except 'get started'. I attached the picture below. I have no idea. what should i do?
2 REPLIES 2
OmkarJ
That is because there is no geometry yet. Once you import the geometry, you will see all those tabs 🙂
in reply to: OmkarJ
To follow your correction, i tried to import any geometry from 'Examples' file in Simulation CFD 2013.
As you can see below, I can't open iam file so i tried to open parasolid file instead.
when I made new design study with parasolid(X_T) example file, CFD 2013 program was automatically shut down. Then I opened the saved file, I got another problem again.
What is the problem?
I really need to learn CFD program in time, plz help me.
