CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
CFD Results to Mechanical SIM
4 REPLIES 4
548 Views, 4 Replies
Dear CFD Experts,
I kindly request you to support me in following issue:
I wanna transfer my CFD results of electronic cooling (Pressure+Temp) into Mechanical Simulation inorder to perform Structural analysis (deflection, fatigue due to thermal heat generation)
1. How to transfer CFD results ?
2. When I tried using RESULT-RESULTS TASK-FEA MAPPING---it asks for "FEA DECK = .INP" file, but I could not find any .inp file
Many Thanks,
Kind Regards,
Ajay.S
4 REPLIES 4
Jon.Wilde
Hi Ajay,
Have you tried this method?
http://vp.telvue.com/preview?id=T01885&video=147697
Kind regards,
Jon
in reply to: Jon.Wilde
Dear Jon,
Many Thanks for the link... Temperature works fine.
-How can I use pressure forces from CFD to SIM Mechanical ?
-How can I use FEA mapping option in CFD ?
Kind Regards,
Ajay.S
Royce_adsk
Hi Ajay,
To map over the CFD pressure results to Mechanical you are going to have to leverage this application.
http://apps.exchange.autodesk.com/SCFD/en/Detail/Index?id=appstore.exchange.autodesk.com%3asimcfdtos...
Thanks!
Royce
Royce.Abel
Technical Support Manager
nhahn
in reply to: Royce_adsk
Is there any method to map pressures to Sim Mechanical 2013?  From CFD 2013?  The app says only good for v2014.
