I am trying to setup a model of a floating roof. I usually do a structural static model with a hydrostic pressure. However ,this time i was asked for a CFD simulation.
The model of the floating roog is:
I was thinking in a model with a fluid divided in two ,one with a specific heigh of fluid and the second one a empty space. The fluid is going to move from down to up.
I am having trouble with the movement of the solid .I setup a free surface motion but the roof do not sink on the fluid.
The other question that i have is :is it possible to export the pressure data of the moving
solid to autodesk mechanical simulation?
You would need to model the air above (although it will be assigned water just with no height of fluid assigned). There is a guide here, which will hopefully prove useful.
I am not sure on exporting the pressure data of a moving part and will leave that to someone else.
hi reshadi
Really depends of the type of simaltion that you want to do. If you consider that the surface behaviour is important for you i will suggest CFD motion . but if you are only interesting in pressures i will sugest simulation CFD and CFD advanced.
I saw years ago a simulation of hydrofoil and they simulate the movement of the fluid trought a static part. It is easy on that way. if you use motion you are going to have to setup the waves,motion of the object and other thinks.
Please open a specific topic over the subject.
HI
Did you tranfer the pressure profiles of the motion solid to autodesk Mecahnical?
hlw!
No i didn't and really don't know much about this profile transfer. I just simply set up a floating body in water.
Thank You!
hi again!
why can' i just find the CFD motion software and its features on outodesk site
Nastaran
Here's a link from a quick Google and here's a page feom our Wiki,
Hello
I checked the mathematic and format of the output files. And i believe that the output matrix is a matrix of the nodes with their respective pressure of wall. That will mean that for Autodesk Mechancial simulation the object is the same than other pressure exported from CFD
Please correct me if i am wrong.
Thank you
