CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
CFD is stopping
4 REPLIES 4
533 Views, 4 Replies
CFD is stopping
I am trying to run CFD on parasolid files i have imported from solidworks. I am setting the boundary conditions inlets 88 fps, outlest pressure 0, and side as slip/ symmetry. Doing an autosize for MESH then adding a region right around where my wing profile is. I set it to enable adaptions 3 runs, 300 iterations, Turb. model to RNG, turb/lam ratio 10, turb intensity .01 . The program will run through the mesh check then just stop with it saying queed... I have ran 2 dozen CFD runs before this with the same parameters and not had a probblem until this past week and now it keeps happening no matter what i do. Am i doing something wrong? Also i am trying yo run these on my Hp laptop A8 AMD i don't know if that is part of the problem. Attatched is the case file. Please HELP
4 REPLIES 4
Anything? Anyone?
Hi Andrew,
aside from your issue I'd stop working with this geometry since it looks to me if it is a perfect fit for a 2D simulation. So just create a planar 2D surface part in CAD and move on with that. should be much quicker.
Marco
OmkarJ
Do you use remote solvers? Are any simulations running? Try to monitor this using Solution Monitor
apolo_vanderberg
in reply to: OmkarJ
Looking at your file I see that you had this on H: drive (is this a network share)?
I would suggest that you move the file to your local harddrive.
