I was trying to setup the CFD icon to Inventor by running the SimCFDConfig.
After that I restarted the computer because it was not appearing in the Inventor >Tools>Add-ins Menu.
Now the only application I have is Autodesk Simulation CFD Viewer. There's no trace of the Simulation CFD application.
Both CFD and Inventor are 2013 versions.
Ran the repair tool and I can't get application back.
Solved by apolo_vanderberg. Go to Solution.
I have not seen the software delete itself.
But overall you might have to reinstall it from the media. I would also ensure you have proper permissions to install and right-click "Run as Admin" when doing so.
Thanks for the quick response.
I tried repairing but it didn't finish the task after an hour.
So I just reinstalled and it worked again.
