Solved by Jon.Wilde. Go to Solution.
Great!
Our tutorials are here: Simuation CFD tutorials.
You could swap the heat flux for a temp I'm sure.
Jon
Hi Chandra,
To answer your questions:
Jon
Hi Chandra,
Sure thing.
Can you share an image of a cut-plane through the model showing the mesh?
Why not just use the auto mesh and refine it a bit? A mesh size of 200 and 0.1 doesn't make sense to me, are you still working in inches?
If you have 8GB of RAM, you should be able to run a model with approximately 4m elements, any more and you may fill the RAM and start using a page file, which is obviously slow.
Right click on the Results Legend and go to Options to change the settings. This will effect the Global Results (which can be selected with a right click in the graphics window, off of the model).
Jon
OK so select the volumes and refine the mesh.
Can I suggest you run through some of our tutorials to learn how to do set these models up? There is a lot of information in the online help.
This is an example of how to refine a mesh.
Kind regards,
Jon
They are both applied to the inlet surface but one is a velocity (for example m/s) and the other is a volumetric flow rate (for example m^3/s).
Does that make sense?
Hi:
Either volumetric flow rate or velocity is applicable- note that volumetric flow rate is simply the velocity x the inlet area.
Hi Jon,
Thanks again. I am still not getting hold of the Mesh number elelemnts. . That is going here and there.
Any more adavannced tutirials, on getting controlling exact elements ? I tried "adavanced options", nothing helpfull.
Best Reagrds,
Chandra
Hi Chandra,
It is first best to assume that the approximate element count is just that, very approximate. So mesh models (run for 0 iterations to do this without solving) to check out the mesh and the mesh count.
Have you tried the basics and comparing the differences?
Mesh autosize
Mesh a slightly refined model (refining the air by 0.7)
Then try uniform meshing some parts and seeing what that looks like.
You can also right click on a part to see the surface mesh preview if it helps.
Kind regards,
Jon
Hi Jon,
I have solved now, my refineing and making approximate control of the elements. Many Thanks.
I have another dificulty here. Pls find my designed Heat sink. when I bring to CFD, its showing me that surafaces and edges should be removed. I removed them. But Simulataion is not happening.
Becuse Unassigned materials. I did suppress them. But If i remove the whole Heat sink disappers in CFD. is my Heatsink structure not acceptable by CFD software here ?
Pls advice.
Best Regards,
Firstly you file will not open so I cannot check it.
If you have unassigned materials in CFD - assign a material to them.
Only use the small object and edge tool if you think it is necessary - are they very small edges/objects?
The design is so simple I would be surprised if it was anything other than CFD making split edges into one solid edge.
Jon
Hi Jon,
Thanks alot for the help. However, I could get the results well. Ony issue was if I open the CFZ file deirectly for the one I sent you latest, Hestsink( club shaped, holes in it).
That gives core-dump/tool crash issue for CFD tool. I need to open from Inventer then re-assign all the materials and then alll BCs, and then Mesh. Then Only every time i can get results.
leave it. I got results some how.
I have few more questions:
1. Is this Autodesk is "FEM" tool ? or Anyltical Modles used or Compacts models used ?
2. Can I see these models in any form . Isf so, can you point me how to see them ?
Best Reagrds,
Chandra
