Solved by Jon.Wilde. Go to Solution.
Hi Chandra,
This is most likely to be an error in the setup, are you able to share a CFZ?
Jon
Hi John,
Pls find the below link to see what is happaning at my side.
http://screencast.com/t/rgCi79Up8
Many Thanks,
Chandra
Looks like a poor setup to me still, at the least the mesh is too coarse. It is tough to troubleshoot this one from a video though, please share a CFZ.
Hi:
The program automatically creates parts where void are detected so you have to assign a material to these, otherwise the solver will not run. You can, of course, suppress these parts (prevent tem from meshing) if you do not want the solver to use them.
Hope this helps.
I am not 100% sure on the goal here yet.
Model 1
I think perhaps you need to draw an air block (in CAD) around the upper portion of this model and apply a flow rate and temp at the inlet and a P=0 at the outlet
You cannot apply flow rates to a solid.
We also must ensure all boundary conditions (BC's) are external - so leave the bottom of the unit outside of the air so you can apply a temperature.
I would not recommend changing the solver settings from the default initially not sure why this is set to laminar?
Model 2
This makes more sense - but just draw a solid block in CAD (in most packages it can overlap the part) and then just call it 'air' in CFD. Apply BC's to this.
Or you can use the Geometry Tools in CFD to fill the solid you have (void-fill) and then be sure to suppress the outer solid part from the mesh to avoid internal BC's. The part you create will be air.
Have you run through any of our tutorial models? This should really help make it clear.
Jon
Hi: This feature is more a convenience in that frequently the original CAD model usually represents the solid parts and SimCFD detects enclosures/voids and creates additional parts- it does not modify the original geometry in the CAD files. This saves the user considerable time by avoiding the need to explicitly create the fluid domain in the CAD environment.
If you do not want the mesher to mesh these you can simply suppress them, but you still have to assign these filled voids a material- any material will suffice.
I can make a few comments:
I hope that helps,
Jon
I can only see a cfdst, please send the CFZ and I'll take a peek 🙂
Mind you, I'm not so hot on using screencast to share files, maybe I'm just not seeing it.
Kind regards,
Jon
Hi Jon,
Thanks for the email. I am sorry , I was doing "uick reply", hence was unable to attcahfile here itself, insted using third part website.
Its OK. Pls have alook with CFZ file, I have put below Boundary conditions:
1. Inlet of air block:
Pressure= 0 psi,
Temparature 22C;
Volume Flow rate: 50 m3/s
2.outlet of the air block:
pressoue =0 psi
3. Bottom of the Square holed heat sink base:
Heat Flux = 4500 w/m2
Heat genaration = 70 Watts( sorry last time I used wrong units here)
Could you pls guide me now.
Thanks agaian,
Chandra
Your conditions need to be:
Inlet
v = 50m3/s (is that really correct? It seems awfully fast!). Maybe you mean m/s?
T = 22C
(We cannot have both vel and pressure at the inlet as the model would be over constrained)
Outlet
P=0
Draw the air box in CAD so the bottom aligns with the unit - so you can have the heat flux outside and not inside the air domain. We must not have internal surface boundary conditions.
Right now you have a really small gap. Whatever you choose next, do make this change, a small gap like this will cause meshing issues.
Do you really need the 70W volumetric load, the 70C temp underneath and the 4500 W/m2 heat flux? I think the temp needs to be deleted. Always check through the setup.
Once you have made those changes - you will need to refine the mesh as the default is going to be too coarse for accurate results. I would start with a refinement to 0.3 and go from there.
Should look something like this. I used 50m/s and was not able to change the CAD as you need to (so I had no heat flux either).
Kind regards,
Jon
