CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
cfd 2013 crashes on startup
9 REPLIES 9
Message 1 of 10
brian
1761 Views, 9 Replies
We are running cfd 2013 on 4 computers.  One is having a problem. On startup after the splash screen I get the following message "autodesk simulations cfd 2013 has stopped working".  I have uninstalled and reinstalled the software.  Still get the same error.  Is there a log I need to look at or system processes I need to check.
win 7 x64
Thanks for the help
Brian Brisbin
National K Works Inc.
9 REPLIES 9
Message 2 of 10
brian
in reply to: brian
We solved it.  It turns out to be a know issue.  "tabletinputservices"
Thanks.
Brian
Message 3 of 10
Royce_adsk
in reply to: brian
For more information regarding this issue:
http://upandready.typepad.com/up_and_ready/2012/06/autodesk-simulation-cfd-2013-crashes-at-startup.h...
Also make sure that 'TabletInputService' or 'Tablet PC Input Service' is disabled in your services list in Windows.
-Royce
Royce.Abel
Technical Support Manager
Tags (1)
Message 4 of 10
in reply to: Royce_adsk
I have got a problem with Autodesk SImulation CFD - I have installed it. When I firstly run the program, it requested code and serial, which I have inserted. Then an error appeared - The program stopped working. I have Windows 7 (64bit).
I  dont have on-screen keyboard. Service 'TabletInputService' is stopped.
Do you know what should fix this?
Thank you!
Message 5 of 10
ghmail16
I have also disabled TableInputServices from Services List but the problem of startup remains?
What is the solution?
Thanks!
Message 6 of 10
Royce_adsk
in reply to: ghmail16
Did you see this solution?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18708426&linkID=18154757
-Royce
Royce.Abel
Message 7 of 10
ghmail16
in reply to: brian
Unfortunately I still have the same problem. I attach a picture to show you what is the message that I get when I try to open it. It is not the same that shows in the page that you cite me.
Thanks Again.
Best Regards!
Message 8 of 10
zeno.lh
What about those of us that need to have the Tablet PC Input Service running?
I have a touch-screen computer that I use for design, and enabling/disabling the Tablet service every time I need to run the simulation is going to get very old, very fast.
Tags (1)
Message 9 of 10
Royce_adsk
in reply to: zeno.lh
Please checkout SP1.  That should fix the issue.
Thanks!
Royce
Royce.Abel
Message 10 of 10
ghmail16
My issue was that I was not opening the programm as administrator. When I run it as administrator it opened normally. 🙂
