CFD doesn't show the bubbles, but it does show the region of cavitation with the vapor fraction.
Straight from the help system:
"The cavitation model tracks the vapor bubble volume fraction and predicts the onset and location of bubble formation within the flow. It is best suited for predicting small regions of cavitation, and does not predict large vapor formations. This cavitation model assumes a collection of bubbles and not a total vapor region.
When cavitation is enabled, the fluid pressure does not fall below the vapor pressure. (If cavitation is disabled, the pressure is allowed to fall below the physical limit.) This improves the accuracy of forces computed by the Wall Calculator when cavitation is present."
So for small amounts of cavitation, the cavitation model helps identify regions of cavitation, give more accurate fluid pressure drops and more accurate wall forces than if you didn't enable cavitation. You can look at scalar to identify the cavitation regions and their severity. The most important thing to recognize is if the cavitation region grows too large, it can go beyond the scope of the capability and cause instability.
Heath
Heath Houghton
Product Manager - Autodesk Simulation CFD
DIRECT +1 512 722 3110
MOBILE +1 512 557 0870
Twitter<>
Facebook<>
Education Community<>
Autodesk, Inc.
7160 Dallas Parkway # 330
Plano, TX 75024-7150
www.autodesk.com<>
[cid:image003.png@01CFDC31.C8446EF0]<>
Find the full overview of Simulation classes here<>
Find the Moldflow Power Track classes here<>
Register here<> before October 19th to take advantage of the $500 early bird discount.
Heath Houghton
Principal Business Consultant
